Radius or angle value ?
Hi everybody,
Is there a simple way to get circle radius or angle value in 3D mode ?
Those function exist in Autocad but in Bricscad i can't find them ?
Thanks in advance,
Best. Fredodb.
  • Hello.
    You could experiment with using the MEASUREGEOM command in V26.
    With older versions, MEASUREGEOM is not implemented.
    In this case, only the data in Properties panel is available.
  • Ok. Thanks for the advice.
    I'll try and get back to you.
    Thx
    Fred
