Block with Attribute value = field = concatenated values of parameters
Dear All,
Is there any way (without any Lisp code) to get the value of an attribute as a concatenated value of 2 parameters (strings of characters).
Here you will find enclosed a block file I wish to modify. It contains 2 parameters made a designtable (dropdown list). I wish I could get the value of Attribute ATT3 = PARAM1.value&"-"&PARAM2.value.
Thank you for your feedback
BR
  • You can simply insert parameters as fields in the attribute value, but the parameters should be numbers not text. Text will not work.
  • This is add two atts and put in third example.
    ; add 2 attributes and put the value as a field into the 3rd attribute.
    ; BY AlanH
    (defun c:test ( / obj lst x )
    (setq oldatt (getvar 'attdia))
    (setvar 'attdia 0)
    (command "-insert" "c" (getpoint "\npick point") 1 1 0 (getstring "\nEnter Att1 ") (getstring "\nEnter Att2 ") (getstring "\nEnter Att3 ") "-")
    (setq obj (vlax-ename->vla-object (entlast)))
    (setq lst '())
    (foreach att (vlax-invoke obj 'getattributes)
    (princ "\n")
    (setq lst (cons (strcat "%<\AcObjProp Object(%<\_ObjId "
    (vlax-invoke-method (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object))) 'GetObjectIdString att :vlax-false)
    ">%).Textstring>%"
    ) lst ))
    (setq str nil)
    (setq x (length lst))
    (setq str (strcat "%<\AcExpr "
    (nth (setq x (- x 1)) lst) " + "
    (nth (setq x (- x 1)) lst) ">%"
    (setq x 1 y 4)
    (foreach att(vlax-invoke obj 'getattributes)
    (if (= x y)
    (Vla-put-textstring att str)
    (setq x (+ x 1))
    (setvar 'attdia oldatt)
    (princ)
    (c:test)
