plot area - window selection
I am having problems with the plot area selection window. I can choose an area, then when I preview the area, a large portion of the selected area is missing. It is typically the left side of the selected area. center plot is on, scale to fit paper size is on. this is not on all drawings - is there a method to scan a drawing and get it repaired?
  • As you have a maintenance, I think it's worth to create a support request and provide a problematic drawing for investigation.
