Change appearance of grips, for dynamic blocks
Hi, is it possible to change appearance of grips for dynamic blocks, the way it looks for example, to make bigger, the colour? See example below.
  • Yes, you can change the size of all grips via GRIPSIZE variable, and control color of dynamic grips via GRIPDYNCOLOR variable. Use the DDGRIPS command for quick access to GRIPS category of Settings dialog.
  • Thanks Lyubov, yes I did see these, it wasn't so much the colour but the appearance, something similar to AutoCAD, with above I have used for a while but still get confused as to what does what
