LISP not working - make block
Hi, I asked this question a while ago but not sorted. The LISP below makes a block of selected objects, it works as posted for other but not on my machine. This is the second computer it's not working on. Is there a setting I need to change?
(defun c:make_block_at_selected_point (/ bkn eee i ndx nm ssst st)
(if (and (setq ssst (ssget)) (setq st (getpoint "\nPick Base Point: ")))
(progn (setq ndx 0)
(setq time (rtos (getvar "CDATE") 2 6)) ; Format YYYYMMDD.HHMMSS
(setq year (substr time 3 2)) ; Two digits instead of four
(setq month (substr time 5 2))
(setq day (substr time 7 2))
(setq hour (substr time 10 2)) ; Increment of 3 from day to account for "." character
(setq minutes (substr time 12 2))
(setq seconds (substr time 14 2))
(while (tblobjname "block" (setq nm (strcat "Block-" year month day hour minutes seconds))))
(entmake (list '(0 . "BLOCK")
'(100 . "AcDbEntity")
'(67 . 0)
'(8 . "0")
'(100 . "AcDbBlockReference")
(cons 2 nm)
(cons 10 st)
'(70 . 0)
(repeat (sslength ssst)
(entmake (cdr (entget (ssname ssst ndx))))
(entdel (ssname ssst ndx))
(setq ndx (+ 1 ndx))
(entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0")))
(entmake (list (cons 0 "INSERT")
(cons 2 nm)
(cons 6 (getvar "CELTYPE"))
(cons 8 (getvar "CLAYER"))
(cons 66 0)
(cons 10 st)
(cons 41 1)
(cons 42 1)
(cons 43 1)
(cons 50 0)
(cons 71 0)
(cons 44 0)
(cons 45 0)
(princ)
Have a look at this example note the "endblock" is the very last line in making the block.
0 -
Thanks but the code is very different and I won't be able to make it work since what I have was from other people's assistance.
By the way, there is a line with ENDBLK in posted code
0 -
What went wrong:
Wrong subclass in BLOCK definition
used AcDbBlockReference instead of AcDbBlockBeginInvalid / unnecessary DXF codes in INSERT
71, 44, 45 caused issues (MINSERT behavior / rejection)Broken name loop
while had no body, could hang on duplicate names
It seems attached code works.2 -
NedCAD, this works, so thanks very much for posting, it may help others as well. I'm not good at LISP at all and generally find it hard to get to a solution, in almost all instances have had to rely on someone to pretty much fix it. Not being a code expert, I manage to get by for other languages such as Visual Basic and HTML/CSS, only because so much is available online, and if not can post on a forum with confidence. With LISP, it's been very difficult and haven't been able to get past the hurdle of understanding the structure of the language, let alone details. I did post regarding this code a few months ago but wasn't resolved, this time it was, consider your skills as a rarity.
1
