AI Assistant
Seeing Jason demonstrating new Bricscad AI Assistant in '3D model and length/thickness issue':
a) which version was this introduced?
b) having not renewed my BC subscription beyond 23.11.25, am I still allowed to download the current version of v26?
c) if not, I have the v26.1.05-1 installer msi. Can I still install it, if that version includes the AI Assistant?
d) after all that, can I still use the AI assistant if I have no current maintenance contract?
  • Lyubov Osina
    edited April 14
    Hi Tom,
    AI Assistant was introduced in the latest V26.2.03. Without maintenance contract you can download and install any release withing your current BricsCAD version, so if you have a license for V26, V26.2.03 with AI Assistant is availiable for you. It doesn't require maintenance contract.
    Here is a short demonstration of this feature:
    https://www.bricsys.com/bricscad/v26?f=v262,bricscad&wistia_id=zw0d6tzfvr
    Best regards,
    Lyubov
  • Thanks. No longer able to use Support, I've been getting on well using ChatGPT instead! It does find all sorts of info and wisdom out there, though not always in the correct version no. Will see whether BC AI helps similarly.
