V26 under wayland crashes when visual style is other than 2wireframe
Hello,
From what I encountered on my end (on Ubuntu), it's an issue with BricsCAD on Wayland.
Some people managed to fix this using the open source Nvidia drivers or older versions of the drivers.
On my end that did not fix it and I had to use xorg.
1 -
Thanks for comment, Eduard.
I am using the opensuse nvidia-open-driver.
I will change to X11 to use Bricscad until this is resolved with Wayland.
1 -
I can confirm that BricsCAD 22, 25 and 26 are crashing on several machines with Nvidia cards as soon as the GUI is going to be drawn when the session uses Wayland.
As the desktop environments that still support X11 are becoming rare, the Wayland-problem is growing more and more serious. Out of security reasons there is no chance that Windows 11 will ever be used for our CAD work, so we depend on BricsCAD running under Linux.
2 -
I opened a support request (SR 219269) with Briscad support and this is the answer:
"This issue occurs due to the combination of Wayland and Nvidia proprietary drivers.
As a workaround until this issue is fixed, you can use X11 with Plasma KDE.
I will inform the development team about this.
Depending on our development team's priorities, available resources,
or the level of requests, they will look into this. However, I can't
give you a timeframe for when this will be fixed. The SR number will be
mentioned in the release notes when the fix will be released."2 -
Is there any way the Linux users can help?
0
