Alignment Profile
How can I modify the vertical alignment view so that the Point of Vertical Intersection (PVI), stationing, data bands, and other related details are displayed consistently within the profile view? just like the image below? Thanks
  • You may want to look at CIVIL add ons for Bricscad that are way more advanced that the out of box version in Bricscad. I used Civil Survey Solutions which has an immense variable output options.
    https://civilsurveysolutions.com.au/
