Communicator
Every time there is an update to Bricscad, I go to use it and discover missing functionality - because the update process didn't remind me I had to reinstall the updated Communicator to go with it.
A little better integration in this process would be welcome.
  • This is a reasonable suggestion, thank you! Communicator until V25 was working if the minor versions of BricsCAD and Communicator did not match. From V26 Communicator is not working if the minor versions don't match.
    There is a task is to inform the users when Communicator version is not the same as BricsCAD and needs to be updated. If you create a feature request about it, this will add a value to the existing task.
