Push/Pull around an axis
Hello ,
I have drawn a rectangle bridge deck slab and now it requires a skew of 20 degrees. It there a way to rotate the slab around the vertical axis / corner to introduce a skew?
  • Hello.
    One way of working could be to experiment with using the SOLIDEDIT command and the option Face > Rotate.
    Alternatively, depending on the design intent, you could enable "Prioritize Selection of Faces" and use the REVOLVE command.
    This approach creates a new 3D solid, so, using UNION might be needed.
