How to install BricsCAD V26 in Ubuntu 26.04
I just tried to install and run BricsCAD V26 on a freshly configured CAD Workstation (Lenovo ThinkStation P3 Tower Gen 2 with Nvidia RTX 5080).
The installation of the .deb package finished without error.
Doubleclicking the BricsCAD icon had no results.
Starting the program with the command "bricscadv26" in the console showed the error message "error while loading shared libraries: libOpenGL.so.0".
This could be fixed with
sudo apt install libopengl0
On the next try, a new message appeared: "error while loading shared libraries: libGLU.so.1".
Well,
sudo apt install libglu1-mesa
Third try: "error while loading shared libraries: libxml2.so.2".
sigh
sudo ln -s /lib/x86_64-linux-gnu/libxml2.so.16 /lib/x86_64-linux-gnu/libxml2.so.2
Finally, BricsCAD started and I could open and edit drawings … as long as I stayed in the visual style "2D-wireframe". Every other visual style lead to the well-known problems with Wayland.
Next step probably will be to install X11 and the Cinnamon desktop …
  • NedCAD
    edited May 29
    In my tar-based BricsCAD tree I do not see bundled libssl.so* or libcrypto.so*. ldd ./bricscad resolves both to the system libraries, e.g. /lib/x86_64-linux-gnu/libssl.so.3 and /lib/x86_64-linux-gnu/libcrypto.so.3. So if these are reported missing, I would first check whether the target system actually provides OpenSSL 3 libraries, rather than expecting them inside the BricsCAD directory.
    About X11: Sounds reasonable. I'm running BricsCAD V26 Linux "custom-version" (latest&greatest), in order not to taint my Linux install, on X11 + XFCE without issues, so testing with X11 could help narrow down whether this is a Wayland-related problem.
  • I installed briccad V26 on a fresh Ubuntu 26 System; mostly did not start, if it started, it crashed when I was simply zooming within a drawing.
    I changed to X11 and XFCE-Desktop, and bricscad mostly works (s, seems to be a wayland-problem). But BricsCAD "forgets" most of my changed options, e.g. concerning chosen type of workspace and the chosen types of snaps. I have to restore this manually every time I use the app.
    Quite annoying.
  • I think it is a good habit to use on_doc_load.lsp and put all your personal requirements there.
    ~/.bricscad contains settings as alternative to the windows registry. Should be a relative stable environment.
