Trying to set a move base point - but it keeps tracking to the ground (Solved: set OSNAPZ=0)
mallenb
edited June 2 in BricsCAD BIM
Hello,
I am trying to move a solid (I'm in a BIM project), and when I try to place the base point for the move on the solid, it tracks to the ground. Is there a way to toggle that off?
EDIT (Newbie here, on a trial…I wasn't sure if this was related to BIM, which is why I posted here, but if a moderator thinks this is better suited for the 3D forum, by all means, please move it there)
  • Hello.
    You could check whether OSNAPZ=1.
    If this is the case, set OSNAPZ=0.
  • That was it! Thank you so much!
