Door insertion ignoring nearest wall (solved: insert THEN reposition)
Hello,
If your walls are connected, the distance to the perpendicular wall should be recognized.
If the walls are connect, please create a Support Request and attach the drawing where you can reproduce this issue.
0 -
Before I submit a ticket - is "connected" different than "touching"? Is there something special I have to do to make walls connect? (Like the example above, I'm talking about when two walls come together at a "T".
I just now created a new empty drawing and used Quick Draw to make a simple 4 wall room with slab floor. I used "wall" with the "single wall" option in the dialog box to place a wall within the 4 main walls. This wall was automatically placed touching two of the outer 4 walls.
I then try to insert a door or window (or anything) on a main wall, and the interior wall is not recognized when I place the object on the main wall.
0 -
Support responded (thanks!) Bricscad is operating as designed. To get objects to recognize perpendicular walls, the walls in question need to each be separate entities. T shaped connections need to look like the photo below, as opposed to my original example above.
I wish walls automatically did this (I'm attempting to migrate from Autocad Architecture where windows and doors automatically recognize perpendicular walls without any special preparations)
0 -
Sorry but I never noticed such behavior or remember anything missing.
I did a small test in latest Bricscad BIM and for me it still works as being used to and as expected :0 -
EDIT :
OK, now I see.
It works different for "placing" a Door than for selecting already inserted Doors ….
(While inserting the DYNDIM runs through)So my recommendation ….
- place the Door anywhere in the Wall
- select the Door again
- in DYNDIM input your desired distance from perpendicular Wall
0 -
Thank you! Doing the "insert then reposition" method works as you have described and is much less fiddly than making every connection mitered.
0 -
Yes, it would not make sense to ruin the connections, especially if you deal with completely different Compositions for your Walls.
But maybe it is worth a Feature Request.
Not sure if there is a reason why it works different when inserting ….0
