kopiowanie arkuszy między rysunkami
Mam pytanie, czy jest możliwe kopiowanie gotowych arkuszy z obszaru papieru do innego rysunku tak żeby zachowane zostały: rozmiar papieru i ustawienia drukowania?
0
Please post English as well. used Google translate. Yes lots of copy layouts to another dwg. maybe as simple as Layout T the T is for template lets you import a layout from another dwg, The simplest is set up the layouts correct but dwg is blank and save as a DWT a master template dwg.
0 -
Thank you for your help. Selecting the "from template" option and then selecting another dwg file with a ready-made sheet helped.
0
