Workspace changing
Using v19.
I just installed v 19 on a new desktop.
Everytime I open a drawing it goes BIM interface, not drafting, and the Model Background is white and not black as I would like it. My .lsp files load no problem. What to do to revert to the workspace that I prefer?
0
Set up your correct workspace and save say as your name, Save As. it should work then. In Acad there is a button update workspace need to make sure that is turned off after making workspace changes. That does not appear in the Bricscad options.
Let us know if that worked else may need to make a profile.
0
