ERSI Map
How can I trim the size of the ERSI image to "a work area"?
Also, I cannot get the ERSI image to appear in paper space for printing?
  • aridzv
    edited June 10
    GEOMAPIMAGE command let you convert and clip/trim the esri image.
    after runnig it, run GEOMAP again and select "off" to turn the GEOMAP off and leave only the cliped area.
    for me this cliped image dose apear in the viewports tabs.
  • Perfect, thankyou so much.
