TIN Volume Cut/Fill Depths Display Plugin for BricsCAD (Windows 11)
Needed an easy way to show earthwork exhibits to LA County plan check. Built a quick plugin that visualizes cut/fill depths in a grid pattern on the TIN volume surface. After generating, select some +/- grid ticks, then select similar and wblock out for a nice and clean xref.
I'm not familiar with dotnet, visual etc. but just wanted to test the plugin.
Following the readme on github i'm getting error-messages concerning type- or namespace "BricsCAD" "Teigha" "CommandMethodAttribute" "CommandMethod" and "CommandFlags".
Can someone give me a hint, what is missing ?
Thanks
Mathias
0 -
Just found it out - in the .csproj i had to change the paths for my german version:
<HintPath>C:\Program Files\Bricsys\BricsCAD V26 de_DE\BrxMgd.dll</HintPath>
0 -
Got completely swamped right after this, planning to try to make this a bit more generic as I want to try this on linux and macos next. I guess the initial idea of stock stock Windows didn't work out the way I thought it would. Going to throw this into and open code GO deepseek to see what it can fine tune to make it as generic as possible so that error doesn't happen.
0
