Can You Make The Status Bar Taller, So You Can See All Your Layout Tabs At Once
Just wondering if there is a way to make the status bar taller. I'd like to be able to see all my layout tabs at once, instead of having to scroll using the right or left buttons or choose a layout tab from the drop-down list.
I've figured out how to make the status bar have two levels by toggling off the "Dock Inline With Status Bar", but I'd like to make it one level higher if possible.
0
Can not help with the question but this may help a bit allows as name implies go to a layout by number, handy when you have 88 layouts, our index was on layout 1 so goto that first and look at layout number required.
0
