new version file open different layout
Hi
Just updated and now my standard file open dialogue isn't showing standard folders as shortcuts and i really miss them.
Any ideas would be great.
Above from the help…..
Thanks
  • Hi,
    Could you please check that USESTANDARDOPENFILEDIALOG variable is On on your side? You can type it in the command line or find in the Settings dialog:
  • Hi
    Yes i had already tried that, thanks
    When set to (1) it is wider, but there is no folders. I've tried dragging, copying allsorts but nothing seems to work. My Bricscad 22 which i discarded a few weeks back worked fine.
  • Hi Lyubov Osina
    No other ideas on this then?
    Thanks
  • Hi @dave_wallington , I didn't observe something similar. If you have a Maintenance contract, it's worth to create a support request for deeper investigation of the issue.
