Layout Copy no longer prompts for a new layout name in V26.2.7
Idavi
edited 11:33AM in 2D Drafting
Hi,
Right-click a layout tab → Copy immediately creates Layout (2) without prompting for a new layout name.
The Help documentation still states that the command should prompt: "Enter new layout name:" before creating the copy.
Is this an intended behavior change or a regression?
  • Hi, it seems was an intended change, but it wasn't reflected in the documentation.
  • Thanks for the clarification.
    Would it be possible to add a system variable or a Settings option to choose between automatic naming and prompting for the layout name? The previous workflow was more convenient for many users and also matches the current documentation.
  • Could you please create a feature support request for this?
