Transparency not showing in layout viewports
Hi everyone, is there any way to make the viewports inside layouts show the transparency of the objects inside?
It plots fine, but I need to see the transparency in real time as to adjust things.
The option to show it is enabled in the model, the layout, and the viewports, but it is not showing any difference.
Layers VP transparency also does nothing.
MacOS 26.6 with BricsCAD 26.2.07 (IT)
Thanks
Does Visual style take effect on this? You can change it on the Properties panel for Model space, when nothing is selected, for viewport in Layout - when viewport is selected.
0 -
Changing the Visual style seems to have an effect.
In a layout, when I select one of the viewports and change the visual style, in some of them the transparency comes out (I don't know however if it's the right amount) and in some it messes up the view.
X-ray seems to be the most close to the actual print settings, but the line weights display are not accurate anymore and the .ctb of that viewport breaks as well.
Also, if I change one viewport, the rest in the selected layout change as well
0
