Regression in V27 regarding DCL dialog initialization
Please have a look at the following dcl definition:
Zellstatus_box :dialog {
label=" Zellstatus ";
:boxed_radio_column {
key="modus";
:radio_button { key="1"; label=" 1: &Aktiv"; }
:radio_button { key="0"; label=" 0: &Passiv"; }
:radio_button { key="-1"; label="-1: Passiv mit &vertikaler Durchleitung"; } spacer;
ok_cancel_help;
when initializing that dialog from ObjectARX using
ads_set_tile(regis,_T("modus"),_T("-1"));
it should set modus to the very last radiobutton, which worked fine til V26 (see png
In V27 Beta however it always sets the very first radio button, which is wrong (see png).
Best regards
Andreas
0
Would you be so kind to report this via Support request?
0 -
Done :-)
0
