2D parametric - refresh
SOLVED
Hi,
Why can't I set parametric dimensions anymore? All new dimensions aren't updated when I adjust them, and the geometry doesn't change, as if there were a display error? Also, the name of the parametric property isn't displayed. (ex. d10 is visible the new one not)
For example, a line is parameterized horizontally, but it only becomes horizontal when I copy and paste it.
The normal refresh function, etc., isn't working, and I couldn't find any settings either.
Please help =)
Could you attach the file if it isn't confidential?
Or just an example of anything that displays the same issues?
0 -
Hi, of course
I've attached the file.But I think there's something wrong with my settings…
0 -
Hi Auroport,
I haven't gone all the way through your drawing, but the Block Standard001, that is in the bottom right of your drawing seems to be part of the problem. If I explode it or delete it, then the other constraints start to work.
0 -
Hi, oh, thanks =)
I'm not exactly sure why it's working now, but it is.
I deleted the block and recreated it, then inserted several dimensions into the blocks, since I was also having the problem where dimensions added to blocks always jump to the block's “frame.”So now it works with multiple dimensions in the block and new blocks.
thanks =)0
