AutoLoader for BricsCAD
I read that there is an autoloader option for BricsCAD. This would be a far simpler approach for third party developers. Where can I find the documentation on how to set these up for applying when V27 is released?
Is there sample data somewhere we can reference as a working base?
0
Do you mean the APPAUTOLOADER? It's available in V26 too.
0 -
There is a sample and a readme in the BRX SDK samples/bundle folder.
0 -
The default path given in the help has some of the folders in the wrong order.
Jason Bourhill
CAD Concepts Ltd
0 -
Actually, the path should be C:\Program Files\Bricsys\ApplicationPlugins, sans roaming. the alternative path seems correct
0 -
Doh, I got close!
0 -
Thanks Jason, this is forwarded to documentation team.
0
