BricsCAD V26 regressions: AutoLISP routines terminate early and multiple MLINE Trim/Extend fails
Has anyone seen regressions in BricsCAD V26 involving Visual LISP entity updates or MLINE editing? Large, mature AutoLISP routines that work flawlessly in V25 and earlier occasionally stop regenerating, terminate early, or behave unpredictably in V26. Additionally, Extend/Trim no longer works correctly on multiple selected MLINEs. Reverting to V25 eliminates both problems. I'm concerned these issues may carry into V27.
Roumen
  • Maybe it's due to your trimextendmode setting.
    https://help.bricsys.com/en-us/document/system-variable-reference/t/trimextendmode-system-variable?version=V26
    The default mode for trim and extend has changed in recent releases.
  • which I'm aware of and has nothing to do with the FACT that in v26 one can't extend/trim MULTIPLE MLINEs - won't select them with fence, crossing window etc.
  • II have also some simple LISP working very well on V25 that often make BricsCAD V26 freeze. The LISP is basically performing overkill but is rarely able to finish its task on V26.
  • (at least one) Problem isolated:
    IAcadModelSpace.InsertBlock / (vla-InsertBlock) > fails when inserting different blocks
    The Release Notes will be like:
    "BricsCAD > Applications
    COM/BRX/.NET
    Inserting and redefining a block with the same name but different case as an existing block, is now working correctly.
    SR227954"
