LAYDEL from a LISP
I am trying to duplicate the functionality of LAYDEL from inside a LISP. ie I need to delete a layer that has entities on it, and entities inside block definitions. They have redone LAYDEL for v26 so at least it works from the command line, if in a very clunky fashion. But I can't get it to work from inside a LISP using any of the command-s type things, because the number of questions is variable depending on whether there are entities inside blocks or not. I'd rather not have to write a LISP that goes through all the block definitions, but if I have to … Anybody got a better solution ?
  • 1 You can select an object to get layer name.
    2 You can select all objects on that layer and erase.
    3 Could test does block have sub blocks, I think that is what your asking. Please confirm
    4 There is get nested block names from a block lisp, you need to get that defun.
  • Hello.
    In my testing with V26, using an sequence like:
    (setq ent_n (car (entsel)))
    (command "_laydel" ent_n "" "_y")
    (graphscr)
    worked fine.
    If the case is more complex, something useful could be to use the CMDACTIVE sysvar to check whether the command (LAYDEL) is still active.
  • The reason you can't control LAYDEL from LISP is that it is also a LISP function.
    : !C:LAYDEL
    #<<FUNCTION> #x38 @1000326af6>
    I would try putting in a support request to ask for the routine to be updated to honour the EXPERT sysvar setting i.e. EXPERT = 5 deletes requested layer without additional confirmation prompting.
  • Thanks for the various suggestions.
    Yes, I have blocks within blocks that have entities on the layer I want to delete.
    Have opted for the simplest solution - I've given up with this 🤣
  • you can roll a lisp function with Python.
    Example AutoLISP execution usage:
    (pylaydel '("1_1_WALLS" "1_CRP_WALLS"))
  • Roumen
    edited September 8
    Long time ago (v23) I found by trial and error method that (at least some) ExpressTools's commands don't work with
    "vl-cmdf" or "command-s", but do with good old "command". LAYDED used to be ET's, latter been documented as a built-in AutoCAD command.
    Virgil's observation may have connection to ET's roots.
    see my wall reminder from that time :)
    Regards,
    Roumen
