MText
Good morning. This is my code into a Excel VBA module:
Sub CreaMTextfromExcel()
Dim bricsApp As Object
Dim MTextObj As BricscadDb.AcadMText
On Error Resume Next
Set bricsApp = GetObject(, "BricsCadApp.AcadApplication")
If bricsApp Is Nothing Then
Set bricsApp = CreateObject("BricsCadApp.AcadApplication")
End If
On Error GoTo 0
………. etc.
Upon executing "Dim MTextObj As BricscadDb.AcadMText", compiler gives me back following error : User-defined type not defined". Could You please help me about it ?
Thankfully Yours, gfg
  • Hello.
    When using V26, maybe checking if references to Bricscad App 26.0 Type Library (x64) and Bricscad Db 26.0 Type Library (x64) are added to the project could help.
  • If your happy to do it the other way around then you can use lisp to read and write an Excel, so could read the text values X&Y string etc and draw in Bricscad. Have a lisp with lots of Excel defuns happy to provide, various authors.
    This may help though
