Tab Text overlapping
How do I stop this happening, cannot read tabs
  • Its not an answer but rather can come in handy, one thing missing is a GOTO like Word etc "Goto a page". I use a number rather than layout name. Were I used to work we had a index sheet would GOTO that page then look up sheet number and run Goto again. A project with 88 layouts worked well.
  • Is that an old version? I don't see the layout manager button
  • Xupicor
    edited October 11
    This is with the very recently updated version. When I hover over a particular layout name — it's readable. But it goes back to scrambled mess when move the mouse cursor away.
    If I undock it, it's still the same.
  • Is it just one dwg or all dwg's with lots of layouts ?
    Maybe do a support request.
  • There is an issue reported via SRs about tabs overlapping after layouts deleting via Layour Manager. BricsCAD restart should restore the displaying.
  • This happened in previous versions for quite some time — you just have to delete layouts and sometimes, though not always, the remaining ones will overlap with what seems is leftover text from the deleted layouts. Closing and reopening a dwg didn't necessarily help, which is strange, but restarting BricsCAD whole did fix it, eventually anyway.
  • Version 27 seems ok now thanks.
