Fractions
I am using V26 of BriscCAD. No matter what I use for the DIMFRAC system variable (2-Not Stacked)
or DIMLUNit (4 - Arcitectural) I get a stacked fraction with a small horizontal line.
What is the secret. On V25 it works fine with DIMFRAC=2 .
  • Hello.
    In my testing, V26 worked fine to create non stacked architectural dimensions.
    This might be important:
    Setting DIMFRAC=2 will affect only newly created dimensions.
    Existing dimensions won't be affected.
    To have existing dimensions to use this setting, the setting needs to be applied to the dimension style.
    There, this setting is Fractional type = None, in Primary units category.
