V27 don't show manipulator rotation in real time
Is the enable view transitions setting (VTENABLE) turned on for zoom/pan and rotation?
0 -
yes,
VTENABLE is set to 3 in V25, V26 and V27,
so it is not that…
0 -
Hello, you can check DRAGMODE command as it controls the appearance of the objects while being dragged or DRAGMODEHIDE system variable.
0 -
Hi @aridzv ,
Patricia is right, as I see, DRAGMODE variable now influences the manipulator operations also. Please try to set it to 1 or 2.
Best regards,
Lyubov0 -
Can confirm that it works with DRAGMODE = 2 (whenever possible)
(Which was already activated here)
0 -
Hi.
yes,
when DRAGMODE=2 it dose work.
but I usually work with DRAGMODE=0 and in V25 it is showing the rotation and that was my goal…
thanks anyway.
aridzv.
0
