BlockReplace vs Attribute Position
Dear All,
How to replace and synchronize a block whose attribute position has been moved. The Lock Position property is set to Yes.
The goal is to replace an original block (Block_OLD) with a new block (Block_NEW) so that the attribute is moved to the position shown on Block_NEW.
Attached is a drawing with an example of two blocks (Block_OLD and Block_NEW).
When using the BlockReplace command to replace Block_OLD with Block_NEW, the ATT1 attribute is not repositioned as it is on Block_NEW.
How can this problem be resolved? Thank you for your help
This may help
; https://forum.bricsys.com/discussion/40581/blockreplace-vs-attribute-position#latest
; Replace block by AlanH OCT 2026
(defun c:roldnewb ( / ss x attreqold blk blkn newb connold objnew)
(setq atreqold (getvar "attreq"))
(setvar "attreq" 0)
(setq cannold (getvar "cannoscale"))
(setvar 'cannoscale "1:1")(setq blkn (vlax-get (vlax-ename->vla-object (car (entsel "\nPick old block "))) 'name))
(setq newb (getstring "\nEnter new block name " T))(if (setq ss (ssget "X" (list (cons 0 "INSERT")(cons 2 blkn))))
(repeat (setq x (sslength ss))
(setq blk (vlax-ename->vla-object (ssname ss (setq x (1- x)))))
(setq scx (vlax-get blk 'XScaleFactor))
(setq scy (vlax-get blk 'YScaleFactor))
(setq rot (vlax-get blk 'Rotation))
(setq xy (vlax-get blk 'insertionpoint))
(if (vlax-property-available-p blk "hasattributes")
(setq atts (vlax-invoke blk 'Getattributes))
(command "-insert" newb xy scx scy rot)
(setq objnew (vlax-ename->vla-object (entlast)))
(if (vlax-property-available-p objnew "hasattributes")
(progn
(setq atts2 (vlax-invoke objnew 'Getattributes))
(setq K 0)
(foreach att atts2
(vlax-put att 'textstring (vlax-get (nth k atts) 'textstring))
(setq k (1+ k))
(vla-delete blk)
(alert "No block objects found")
)(setvar 'cannoscale cannold)
(setvar 'attreq attreqold)
(princ)
(c:roldnewb)0 -
attsync command?
0
