Calculated parameter can no longer be set to exposed in V27
In Mechanical it is possible to have a parameter that calculates its value from other parameters and constants, e.g. to calculate a total length that is controlled by multiple parameters instead of one such as can be done with some sheet metal objects.
With mechanical components this calculated parameter could be set to exposed so that it would also show in the BOM. With mechanical blocks it looks like any calculated parameter can no longer be set to exposed to make it show up in the BOM the same way as with mechanical components, nor can it be selected in the BOM manager under parameters.
Is this by design and is the full functionality of mechanical components not yet implemented (if it ever will be) or a bug? I "hope" the latter because if it is the former then it is yet another loss of functionality/usability when moving to a new default.
Hello.
It appears that, in newer versions, the Expose property is available only in the Parameters Manager.
Other than that, using parameters in BOM should work as before.0 -
Hello Virgil,
Thanks for the information, I did look in the parameters panel as well but did not see it for calculated parameters.
Other parameters did show an expose option if I recall correctly.
I will take another look and let you know.0 -
Just took a look, exposed does not show up for any parameter in the parameters pane, only create design table/animate/delete show up when right mouse button click on it.
Could experimental being activated interfere with this? In that case this might be a possible bug. In V26 this does not happen, exposed is available to set to ON/OFF and it shows up in the BOM without issues, just have to set exposed to on, it is only a problem in V27.
Dimensional constraints do have an expose on/off option though in V27.0 -
Just to be sure it was somehow not still a component I did a CONVERTCOMPONENTSTOBLOCKS command in V27.
Non-calculated, i.e. standard dimensional, parameters do show up in the parameters manager panel and in the mechanical browser.
Calculated (dimensional) parameters do not show up in either one.0 -
Hello.
It might be that, by default, calculated parameters are set as not exposed, unlike non-calculated parameters.
If the Expose column is not shown, right-clicking on the header row in the Parameters Manager displays a context menu.
This context menu can be used to display or hide columns.
It should be possible to display the Expose column this way.0 -
Hello @Virgil
Thanks for the info on the context menu to hide/show columns, this solved the issue to be able to set expose to on.
Because it increases the width of the group the parameter manager panel was in I moved it to another panel group. This caused the columns to become very wide. Is there a way to set a default width for the columns so that they don't become very wide?
0 -
Hello.
There is no specific numeric setting to adjust the column widths in the Parameters Manager.
The column widths can be adjusted by positioning the mouse cursor between two columns in the panel header and dragging to the left or right while pressing the left mouse button.0
