Identifying system glyphs
Is there a list of the glyphs used in Bricscad? In V27 there is a new one that I don't recognize. I would like to turn it off because it is distracting, but without knowing what it is it is very hard to find the right system variable.
0
Simply put, that glyph indicates your mouse is hovering over more than one entity.
0 -
This is indeed the symbol for the overlapping entities. You can turn it off using SELECTIONCYCLING system variable:
0 -
Thank you. It would be good if your documentation had a table identifying system symbols.
0
