DevExpress, anyone use this for .NET plugins?
Anyone use DevExpress for .NET plugins, or know any freelancers who can recompile a .NET 4 plugin into .NET 8/10?
  • The transition from NET48 to NET8/10 (CORE) is not simple and requires a lot of work. Also all the NuGet's you use need to be compatible.
    NET CORE also does not have simple support for ActiveX, OleDb, all the things unique to Windows.
