Questions about making the move to BricsCad from Acad
I am seriously considering moving our office to BricsCad from AutoCAD. My company currently uses both vanilla AutoCAD and Civil 3D for our civil engineering work, depending upon what is needed for a particular job. We purchased the last perpetual licenses you could get for AutoCAD/Civil 3D, which is 2017 and we have not upgraded since. They work for us, and we would keep using these old versions except that Autodesk has screwed their customers yet again by breaking our licenses.
After reading some of the other posts in this forum, I am concerned about this decision. I want to know from other civil engineers who have made the switch if it was worth it. It seems like it is a no-brainer given what Autodesk charges for Civil 3D, but have there been any glitches with public agencies who require drawings submitted in Civil 3D format? For civil engineering and surveying, has changing to BricsCad caused you any unforeseen problems or expenses? How much work did you have to do transferring ribbon menus and other customizations to make the switch?
Another very important concern I have is whether Bricsys values their existing customers. Have you noticed a trend toward behavior like we see from Autodesk, Microsoft, and Adobe who devise ways to break all or some of their software if licenses aren't kept up to date? How much trust do you have that Bricsys will do the right thing (like fix bugs) even if it isn't the most profitable? I am sick of my company being used as a perpetual ATM for corporate shareholders instead of being treated like a valued customer. It is easy for a huge software developer to treat one small customer like they don't matter, so I don't want to put a bunch of work into switching over to another company that treats their customers poorly when we could just keep getting screwed by Autodesk without the hassle. I don't mind subscribing to support services for assistance from a human being, but not paying perpetually for yearly updates I don't want or need or paying extra for support from an AI chatbot.
I’m not in the Civil space;
- I recommend to push hard on the trial to see if it fits your workflow.
- I’ve found support from Bricsys to be first class.
- Generally, bug fixes are released quickly
- Missing feature may take more time, or might not fit in the overall plan, it’s important to work through a job first
- The APIs are robust, likely you will be able to find workaround for features that are missing.
0 -
Hi @DPE4JC ,
As one of BricsCAD's human beings, I assume you that we are here to help you, with a restriction - you need to have a Maintenance contract to be able to create a Support request. But when possible, we answer questions on the forum also.
I agree with recommendation about trial - check your workflows and settings to be sure that program suits your needs. Also I suggest to check the existing Civil tools in our Help:
and look for necessary options and procedures in the Learning Center:While trial you are able to create Support requests to get additional explanation of desired options or resolve troubles.
Best regards,
Lyubov0
