Layers in sheets
I have imported a drawing file into a sheet. They are cabinet drawings and I create viewports on the sheets at different scales. I would like to turn off certain layers in one viewport but not the other. It appears I cannot do that. If I shut off a layer of text or change a layers properties in one viewport it does to all. Is this correct or is there a command I am missing?Thanks,Paul
Certainly possible, though I'm not sure if I'm using the correct or most efficient method.In Layout tab, select ModelSpace (Tilemode off), select the relevant Viewport, open Bricscad Explorer and Freeze any unwanted layers under the Current Viewport heading. Finally return to Paperspace
0 -
Thanks Andy, I think that worked!
0 -
Here's a more complete explanation http://www.cadinfo.net/icad/vplayer.htm
0
