selecting hatch areas
V.7 - When I try to select a hatch area, the prompt "select point for hatch area" merely reappears, and nothing happens.Sometimes, if I choose a boundary set, instead of the default, "everything visible", it will select the area - but not always. Then, if I go back to the bhatch window, the "select boundary set" tab is grayed out. It won't let me try that without restarting the whole hatch command again.
If you feel this problem only happens in a specific situation could you create a Support Request and add the relevent drawing to it so we can analyse this.
0 -
No, happens all the time. I have sent files in for analysis, and the reply was " we have no problem hatching".I still do.
0 -
No, happens all the time. I have sent files in for analysis, and the reply was " we have no problem hatching".I still do. By the way, why does the "select boundary set" tab go dormant when I acivate the "select area" tab? If the "select area doesn't work, I try to go back and select a boundary set, which SOMETIMES works. But I have to restart the whole hatch window to do this. It's cumbersome.
0
