Snapping to blocks
Most times snapping to lines within blocks before exploding is impossible. Can this be fixed?
This will improve if you select which snap to use (transparently) instead of relying on the running object snap (which is usually configured to multiple snap points)
0 -
I think you mean that it is much too slow with some blocks.We will do a big effort to improve this.regards, sanderb|n
0 -
No it is not much too slow or have anything to do with multiple snaps being on the same time. It simply will not snap some times. If you require a real dwg to test it on let me know your e-mail address so that I can send you one. My address is av@computersupport.itgo.com
0 -
email is visible next to the username on mousover(hover):)regards, sanderbricsnet
0 -
No, i mean statusbar. Or link properties
0 -
Thanks I will find I file and send it to you soon.Andreas
0 -
just a test of the new forum
0 -
This is a bit strange but try loading the blocks you cant snap to from disk (overwrite).VIOLA, they can be snapped.Dont ask me why but it works on my drawings.
0
