Bricscad & Ubuntu 10.10: the main menu doesn't work
Please help: the main menu isn't displayed. The problem doesn't depend on version Bricscad.
  • Based on the reply to a support request I submitted, you can use the command line instruction 'cui'
    followed by clicking on 'Revert to defaults...' and this will cause a redisplay of the menu.
    Unfortunately this instruction is not retained after exit from the program and must be repeated each time.
    I thought it was a problem only on my machine so I did not submit another support request.
  • Thanks, however it not an exit. This problem should be solved the developer.
  • Tell, what programs at you are installed? In "naked" system all works. And this problem not in options /home.
    What version at you Ubuntu? Netbook edition?
  • The problem is the menu or the toolbars? I had problem with the toolbars with the spanish version, after install all are tourned off.
  • @Denis:
    My computer is an ultra quiet (no fan) Intel motherboard running the Atom D510 dual processor.
    Ubuntu version 10.10, Linux kernel 2.6.35.22-generic, GNOME 2.32.0. Always up to date.
    It is the Netbook edition because 10.04 standard caused strange loss of configuration of the desktop.
    @Maximiliano
    The problem is the main menu. The toolbars are displayed. The same problems occurs with Bricscad Linux Version 11 beta.
