VBA
Do you have any idea why linux version of brics doesn't support vba and will it be soon? This might give me a chance for not working with microsoft.
Best regards.
I really doubt they CAN, simply because it is a microsoft language. I remember reading that they were hoping to put in some kind of windows emulation for that type of software, but I am unsure. I am currently converting a VBA application into pure AutoLisp, and it's quite time consuming.
VBA is not supported for Linux, because it is an implementation of Microsoft.
And I agree with Daniel regarding LISP.
What you're doing is also a piece of programming knowledge! What is gonna happen for just USERS !? I believe it is possible that is why I wondering when?...
I'm actually still in school as a programmer, not an engineer, and this is the field I'm hoping to get into. And I'm sure it -is- possible but I'm letting you know it will probably be very unstable just because nobody (other than Microsoft) really knows how VBA works. I'm gunna see if I can find that original post.
Well according to the release notes:
The BRX (Linux) SDK includes a "Windows Platform Emulation" layer which allows to use Windows-based developer source code to be used under Linux. The Windows Platform Emulation layer includes a wide range of functions, classes and interfaces fromnative (Ansi + Unicode) Windows C-Runtime and WinSDKnon-GUI MFC classes (CArray, CList, CString and many derivates)COM-based data types and data classes, and related utility functions (Variant, SafeArray, BSTR, CComBSTR etc.)
Unfortunately, that is pretty vague and doesn't really tell us if VBA will be usable..
Oh wow I'm sorry I read that wrong at first. That's for actual developers so they can create C/C++ code that will work with it. So looks like probably no VBA.
Daniel,
Thanks for the info, I have the same idea with you. In this point we need someone from brics in the forum. I will look forward for a clear reasonable response.
Best regards
Dear All,
just to take any doubt away - there will never be a chance to get VBA on Linux; simply, because it is MS, deeply combined with VB language *AND* COM ...
What we provide as "Windows Platform Emulation" is a first stage to support Windows based BRX C/C++ source code under Linux - providing some ATL + COM +MFC(nonGUI) + WinSDK functionality.
Specific documentation will follow on "BRX Linux" ...
A second stage may incorporate more COM stuff, but strictly related to the CAD-system's (Bricscad) COM objects.
Many greetings to all, Torsten0
