Opened drawing on startup
Just getting into Bricscad. Currently ver 11 opens a new dwg on startup.
Can that be changed to 'No drawing on startup' or however its put please?
From past experience I know there was a change to the registry (from memory), that just caused the Cad program to open without a drawing.
I've searched help but not sure what to ask it?
Input much appreciated thanks
  • I don't know about a registry solution. But you could try this solution:
    http://forum.bricsys.com/discussion/13868
    Hi Richard,
    If you go to the Bricscad menu, and go to File -> New Wizard. there is an option called "Start from scratch". I believe this what you want. This would start Bricscad without a template DWG or DWT.
    Regards
    Rakesh
    http://rakeshrao.typepad.com
  • Thanks fellas.
    Rakesh that works but its not really what I had in mind.
    Roy I did that and it crashed or shut down Bricscad immediatley.
    What I want is just for BC to load but without any dwg or offer to open anything
    That way I can go to File and pick the dwg from recent files.
    I know there was a simple tweak to something in previous Cad - can't for the life of me think what though.
    Richard,
    I understand what you mean. There is no way to lauch Bricscad and have it just wait there without opening any drawing (not even a Drawing1.DWG).
    In fact, even in AutoCAD, I could not do it. It seems that in both AC and BC, you would first land in a blank drawing and you must close it later if you don't like it. Closing it later with a Lisp works, and will leave you in the Bricscad startup screen, and not throw you back into the OS. But running the Lisp as part of on_start.lsp simply starts and shuts Bricscad.
    Perhaps Bricsys can consider if this request is worth implementing a command-line switch - to open Bricscad without a document.
    Regards
    Rakesh Rao
    www.coordsys.com
  • thanks Rakesh.
    I'll send a suggestion off.
    It may have been FelixCad where I first encountered this and thats many years ago.
    regards
    Richard
  • To clarify:
    1.
    The solution in this link:
    Works on BC10.
    2.
    The solution doesn't crash BC11.4.5 on Win XP but there is a glitch:
    The command line twice reads:
    'This command is available only when a drawing is open.'
    Strange that Richard gets a crash.
    3.
    This solution works on both BC10.5.6 and BC11.4.5 on Win XP:
    Create an on_start.lsp with this content:
    (if (zerop (getvar "dwgtitled")) (setvar "users1" "close")) (princ)
    Create an on_doc_load.lsp with this content:
    (if (= (getvar "users1") "close")
    (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "_.close ")
    (princ)
    4.
    @ Rakesh Rao:
    Note that it is not on_start.lsp that closes the drawing, on_doc_load.lsp does that.
  • just adding (command "close") in on_start.lsp should work. If it doesn't work then this is worth investigating. (command "close") should be the last line in on_start since lisp can only work when a drawing is open.
  • Test 1: (command "close") in on_start.lsp:
    Bricscad shuts down.
    As mentioned by Rakesh Rao.
    Test 2: (command "close") in on_doc_load.lsp:
    As mentioned in post #7.
    Using (vla-sendcommand) solves this.
    My solution uses both on_start.lsp and on_doc_load. The advantage of this solution is that if you start BC by double clicking a dwg in explorer, BC will not auto-close it.
    BTW: In all cases the variable acadlspasdoc should be off.
  • I've found (In Win 7) that if I run BC from the START menu and slide out the 'Recent Files' view then click one, BC fires up and only the selected dwg is opened.
    Some interesting observations:
    I put (command "._Close") in on_doc_load.lsp and it opened Bricscad with "Drawing.dwg", closed it immediately and dropped me at the point where no document was open. At this point, now, Lisp does not work (until a drawing is opened).
    So, this works but it is not useful. Any new drawing I try to open is immediately closed by the close statement in on_doc_load.lsp
    What I think may be useful for some is to be able to start Bricscad with no document open. Ideally, a command-line switch for bricscad.exe makes the best sense. What do you guys think?
    Regards
    Rakesh Rao
  • If you put (command "close") in on_start.lsp it will work but only if there is no on_doc_load.lsp.
    If on_doc_load.lsp exists bricscad will close altogether. That is a bug and we'll fix it in V12.
  • Greetings to All,
    as Alexander mentioned, there was indeed a problem, when
    (command "_close") is placed in "on_start.lsp", and another Lisp
    file like "on_doc_load.lsp" was was present ... it is just fixed in our internal code.
  • Just a hint, when using (command "_close") inside "on_start.lsp" file, to get
    rid of initial drawing :
    it is essential to set ACADLSPASDOC=0 before - otherwise, you can no longer
    open any drawing at all ...
    ACADLSPASDOC=1 means, that "on_start.lsp" is run for any drawing just opened
    (like "on_doc_load.lsp"), thus that just-opened drawing gets closed by "on_start.lsp") ...
    So in "on_start.lsp" you should place :
    (setvar "AcadLspAsDoc" 0)
    (command "_close")
    Greetings to all
  • The interesting thing is that since I've been fiddling with the settings for this I now don't have the list of last files used in Start- Brcscad flyout in Win 7 that I have come to really appreciate.
    I had found if I just used one of those as a way to start BC it got over this problem.
    But now thats not an option.  Is there a way of restoring that Windows feature please?
