SQLite for autoLisp
I've made a build of my SQLite for Autolisp routine for V12, here is the link
http://www.cadext.com/downloads/SQLiteLsp.zip
SQLite is a software library that implements a self-contained, serverless, zero-configuration, transactional SQL database engine. SQLite is the most widely deployed SQL database engine in the world.
SQLiteLsp is a BRX module with the SQLite engine embedded inside, it's a crazy fast database for lisp
Enjoy
Would love to check this out... but I would have to download and install bricscad for windows, just to do that
Do you have any plans releasing this for Linux, too?
Hi Daniel,
thanks for the tools you are offering to the Bricsacd community...!
You could propably answer as a developer my question....(i have posted it in the developer forum as well)
Is it possible to access via BREP API + C# .NET- the Face/Edge Subentities of a 3D solid ????
I am testing the BREP API of V12 TD_MgdBrep.dll as exposed to .NET !
The following simple C# command colorates all faces of a 3D ACIS Solid3D in AutoCAD
by accessing the subentity IDs of the Faces (or Edges).
The Autocad Lines are out-commended and replaced with the V12 lines in red ...
using System;
using System.Collections.Generic;
using System.IO;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.BoundaryRepresentation;
// system
using System;
using System.Text;
using System.Diagnostics;
using System.Runtime.InteropServices;
using System.IO;
// ODA
using Teigha.Runtime;
using Teigha.DatabaseServices;
using Teigha.Geometry;
using Teigha.BoundaryRepresentation;
using Teigha.Colors;
// Bricsys
using Bricscad.ApplicationServices;
using Bricscad.Runtime;
using Bricscad.EditorInput;
// alias
using _AcAp = Bricscad.ApplicationServices;
using _AcDb = Teigha.DatabaseServices;
using _AcGe = Teigha.Geometry;
using _AcEd = Bricscad.EditorInput;
namespace ColorateSolidFaces
public class Commands
[CommandMethod("CSF")] //ColorateSolidFaces
public void FacesColor()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptEntityOptions peo = new PromptEntityOptions("\nSelect a 3D solid: ");
peo.SetRejectMessage("\nInvalid selection...");
peo.AddAllowedClass(typeof(Solid3d), true);
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK)
return;
using (Transaction Tx = db.TransactionManager.StartTransaction())
Solid3d solid = Tx.GetObject(per.ObjectId, OpenMode.ForWrite) as Solid3d;
//ObjectId[] ids = new ObjectId[] { solid.ObjectId };
// Autocad !
// FullSubentityPath path = new FullSubentityPath(ids, new SubentityId(SubentityType.Null, IntPtr.Zero));
List<SubentityId> SubentIds = new List<SubentityId>();
// Build the BRep topology object that will be traversed.
// Autocad !
//using (Brep brp = new Brep(path))
using (Brep brp = new Brep(solid))
// SubentityID not yet implemented ! ???
foreach (Teigha.BoundaryRepresentation.Face face in brp.Faces)
SubentIds.Add(face.SubentityPath.SubentId);
short colorIdx = 1;
foreach (SubentityId subentId in SubentIds)
Color color = Color.FromColorIndex(ColorMethod.ByColor, ++colorIdx);
solid.SetSubentityColor(subentId, color);
Tx.Commit();
As seen, I cannot use Subentity paths because there is not method Brep(path) to use in the expression
Brep brp = new Brep(path);
So i used the existing one Brep(solid)
The program compiles and net-loads without any Errors but after selecting a Solid
an error message will be shown :
Message : Not implemented yet
Stack Trace: bei Teigha.Runtime.Interop.Check(Int32 returnValue)
bei Teigha.BoundaryRepresentation.BrepEntity.get_SubentityPath()...
etc.
As expected without Subentitypath Access, no subentity access ???Or one could propably use GraphicsMarkers to get subentities ??
To finalize :
Is there a way to access Subentities of a Solid3d via C# .NET and BREP and change their Colors ?
If it is possible, please show it in a code snippet !
Many thanks
Best Regards
KonstantinHeidelberg-Germany
Here is a 'very' beta version for v12b, tested on ubuntu-11.10 compiled on gcc 4.6 : |
cheers!
