SQLite for autoLisp
I've made a build of my SQLite for Autolisp routine for V12, here is the link
http://www.cadext.com/downloads/SQLiteLsp.zip
SQLite is a software library that implements a self-contained, serverless, zero-configuration, transactional SQL database engine. SQLite is the most widely deployed SQL database engine in the world.
SQLiteLsp is a BRX module with the SQLite engine embedded inside,  it's a crazy fast database for  lisp
Enjoy
  • Would love to check this out... but I would have to download and install bricscad for windows, just to do that :(
    Do you have any plans releasing this for Linux, too?
  • Hi Daniel,
    thanks for the tools you are offering to the Bricsacd community...!
    You could propably answer as a developer my question....(i have posted it in the developer forum as well)
    Is it possible to access via BREP API + C# .NET- the Face/Edge Subentities of a 3D solid ????
    I am testing the BREP API of V12   TD_MgdBrep.dll   as exposed to .NET !
    The following simple C# command colorates all faces of a 3D ACIS Solid3D  in AutoCAD
    by accessing the subentity IDs of the Faces (or Edges).
    The Autocad Lines are out-commended and replaced with the V12 lines in red ...
    using System;
    using System.Collections.Generic;
    using System.IO;
    using Autodesk.AutoCAD.ApplicationServices;
    using Autodesk.AutoCAD.Runtime;
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.Geometry;
    using Autodesk.AutoCAD.EditorInput;
    using Autodesk.AutoCAD.Colors;
    using Autodesk.AutoCAD.BoundaryRepresentation;
    // system
    using System;
    using System.Text;
    using System.Diagnostics;
    using System.Runtime.InteropServices;
    using System.IO;
    // ODA
    using Teigha.Runtime;
    using Teigha.DatabaseServices;
    using Teigha.Geometry;
    using Teigha.BoundaryRepresentation;
    using Teigha.Colors;
    // Bricsys
    using Bricscad.ApplicationServices;
    using Bricscad.Runtime;
    using Bricscad.EditorInput;
    // alias
    using _AcAp = Bricscad.ApplicationServices;
    using _AcDb = Teigha.DatabaseServices;
    using _AcGe = Teigha.Geometry;
    using _AcEd = Bricscad.EditorInput;
    namespace ColorateSolidFaces
        public class Commands
            [CommandMethod("CSF")] //ColorateSolidFaces
            public void FacesColor()
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                Editor ed = doc.Editor;
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect a 3D solid: ");
                peo.SetRejectMessage("\nInvalid selection...");
                peo.AddAllowedClass(typeof(Solid3d), true);
                PromptEntityResult per = ed.GetEntity(peo);
                if (per.Status != PromptStatus.OK)
                    return;
                 using (Transaction Tx = db.TransactionManager.StartTransaction())
                    Solid3d solid = Tx.GetObject(per.ObjectId, OpenMode.ForWrite) as Solid3d;
                    //ObjectId[] ids = new ObjectId[] { solid.ObjectId };
                    // Autocad !
                    // FullSubentityPath path = new FullSubentityPath(ids, new SubentityId(SubentityType.Null, IntPtr.Zero));
                    List<SubentityId> SubentIds = new List<SubentityId>();
                    // Build the BRep topology object that will be traversed.
                    // Autocad !
                    //using (Brep brp = new Brep(path))
                    using (Brep brp = new Brep(solid))
                        // SubentityID not yet implemented ! ???
                        foreach (Teigha.BoundaryRepresentation.Face face in brp.Faces)
                            SubentIds.Add(face.SubentityPath.SubentId);
                    short colorIdx = 1;
                    foreach (SubentityId subentId in SubentIds)
                        Color color = Color.FromColorIndex(ColorMethod.ByColor, ++colorIdx);
                        solid.SetSubentityColor(subentId, color);
                    Tx.Commit();
    As seen, I cannot use Subentity paths because there is not method Brep(path) to use in the expression
    Brep brp = new Brep(path);
    So i used the existing one Brep(solid)
    The program compiles and net-loads without any Errors but after selecting a Solid
    an error message will be shown :
    Message : Not implemented yet
    Stack Trace: bei Teigha.Runtime.Interop.Check(Int32 returnValue)
                         bei Teigha.BoundaryRepresentation.BrepEntity.get_SubentityPath()...
    etc.
    As expected without Subentitypath Access, no subentity access ???
    Or one could propably use GraphicsMarkers to get subentities ??
    To finalize :
    Is there a way to access Subentities of a Solid3d via  C# .NET and BREP and change their Colors ?
    If it is possible, please show it in a code snippet !
    Many thanks
    Best Regards
    Konstantin
    Heidelberg-Germany
    Here is a 'very' beta version for v12b, tested on ubuntu-11.10 compiled on gcc 4.6   : |
    cheers!
    SQLiteLspV12x32.zip
