pasteblock in V12
Hi
I have a little problem with command pasteblok. I`m using it realy quite often, but with new version - 12.1.5. I cannot. Ctrl+shift+C is OK, but if I want to copy some entities from drawing to drawing, it works only a few times. 2 or 3 times. When I wont to do it again, BC says - Key not found - .
Do you have any ideas what to do?
Thanks
I have submitted a support request with a drawing attached that causes the same problem. Hopefully they can track the issue down as I have no current way of copying data out of that particular drawing without reinstalling an older version.
Regards,0 -
I did it too. And hope for good result.
I send also SR. When I have in DWG ALIGNED (justify) text, it get KEY NOT FOUND.
...but when I have ALIGNED text in BC, it make another problem - make SLOWDOWN whole BC when panning. It's another SR.
i have the same problem :
: _copybase
Select base point:
Select entities to copy to the clipboard:
Opposite Corner:
Entities in set: 52
Key not found
solution ???0 -
Try last version of BC. It was fixed and working properly.
I`m doing it this way - select entities - ctrl+shift+c - select base point - ctrl+shift+v - select insert point and it works fine for me now.0 -
i upgrade, and now works !
thanks0
