pasteblock in V12
Hi
I have a little problem with command pasteblok. I`m using it realy quite often, but with new version - 12.1.5. I cannot. Ctrl+shift+C is OK, but if I want to copy some entities from drawing to drawing, it works only a few times. 2 or 3 times. When I wont to do it again, BC says - Key not found - .
Do you have any ideas what to do?
Thanks
  • I have submitted a support request with a drawing attached that causes the same problem.  Hopefully they can track the issue down as I have no current way of copying data out of that particular drawing without reinstalling an older version.
    Regards,
  • I did it too. And hope for good result.
  • I send also SR. When I have in DWG ALIGNED (justify) text, it get KEY NOT FOUND.
    ...but when I have ALIGNED text in BC, it make another problem - make SLOWDOWN whole BC when panning. It's another SR.
  • i have the same problem :
    : _copybase
    Select base point:
    Select entities to copy to the clipboard:
    Opposite Corner:
    Entities in set: 52
    Key not found
    solution ???
  • Try last version of BC. It was fixed and working properly.
    I`m doing it this way - select entities - ctrl+shift+c - select base point - ctrl+shift+v - select insert point and it works fine for me now.
  • i upgrade, and now works !
    thanks
