2D Constraints
Strange questions. Is somewhere tutorial or anything, how this work and use it in BC?
Make sure the 2D constraints toolbar is on then try these:
Thanks Daniel. I try it, but if I understand how it work, I'm not sure how it work ie. HORIZONTAL.
...say that I know how to make horizontal constraints, but... when I click on this constraint dimension, BC do nothing, if try edit it (ddedit, ed...) it do also nothing, I can't change dimension value. Also in properties bar I can't change nothing.
But also, when I make copy of entity with constrain, copy have "destructed" constraintand it is only dimension.
This isn't alternative to dynamic blocks. If I understand well.0
