Thanks Daniel. I try it, but if I understand how it work, I'm not sure how it work ie. HORIZONTAL.
...say that I know how to make horizontal constraints, but... when I click on this constraint dimension, BC do nothing, if try edit it (ddedit, ed...) it do also nothing, I can't change dimension value. Also in properties bar I can't change nothing.
But also, when I make copy of entity with constrain, copy have "destructed" constraintand it is only dimension.
This isn't alternative to dynamic blocks. If I understand well.
Make sure the 2D constraints toolbar is on then try these:
http://www.youtube.com/results?search_query=autocad+2d+constraints&oq=autocad+2d+constraints&aq=f&aqi=&aql=&gs_sm=e&gs_upl=3108l9504l0l9914l24l24l1l8l1l1l424l2600l2-6.1.2l9l0
