Materials V12.1.16
in Linux
The Materials are working for the most part but while in the material window if i switch from the sphere to either the cube or cylinder it crashes to the desktop.
running, LD_LIBRARY_PATH=/opt/bricsys/bricscad/v12 gdb /opt/bricsys/bricscad/v12/bricscad
I get
[Thread 0xa361fb70 (LWP 17401) exited]
[Thread 0xa24feb70 (LWP 17406) exited]
The program 'bricscad' received an X Window System error.
This probably reflects a bug in the program.
The error was 'GLXBadDrawable'.
(Details: serial 227706 error_code 149 request_code 136 minor_code 5)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
Program received signal SIGSEGV, Segmentation fault.
0x1f090605 in ?? ()
(gdb) bt
#0 0x1f090605 in ?? ()
#1 0xb4458277 in OdDbDatabase::release() () from /opt/bricsys/bricscad/v12/libTD_Db.so
#2 0xb7c1fb88 in OdSmartPtr::~OdSmartPtr() () from /opt/bricsys/bricscad/v12/libodapp.so
#3 0xaec4ae14 in __cxa_finalize () from /lib/i386-linux-gnu/libc.so.6
#4 0xb60a1f64 in __do_global_dtors_aux () from /opt/bricsys/bricscad/v12/libwxgui.so
#5 0xb67d1f50 in _fini () from /opt/bricsys/bricscad/v12/libwxgui.so
#6 0xb7ff0c3d in ?? () from /lib/ld-linux.so.2
#7 0xaec4aa6f in ?? () from /lib/i386-linux-gnu/libc.so.6
#8 0xaec4aacf in exit () from /lib/i386-linux-gnu/libc.so.6
#9 0xae774921 in ?? () from /usr/lib/libgdk-x11-2.0.so.0
#10 0xae1ac0a5 in _XError () from /usr/lib/i386-linux-gnu/libX11.so.6
#11 0xae1a90ea in ?? () from /usr/lib/i386-linux-gnu/libX11.so.6
#12 0xae1a9ca5 in _XReply () from /usr/lib/i386-linux-gnu/libX11.so.6
#13 0xaef09070 in ?? () from /usr/lib/nvidia-current/libGL.so.1
#14 0xa9961dfc in ?? () from /opt/bricsys/bricscad/v12/libREDOpenGL.so
(gdb)0 -
yep, mine crashes too, probably a minor issue with the preview.
I must say overall, the 3D is working well. I'm still trying to figure how to get my two GTX560s in SLI mode, but just with one things are snappy.
ok7.png0 -
same here, everything i need is working so i'm not complaining, just letting them know.0
