Materials V12.1.16
The Materials are working for the most part but while in the material window if i switch from the sphere to either the cube or cylinder it crashes to the desktop.
  • running, LD_LIBRARY_PATH=/opt/bricsys/bricscad/v12 gdb /opt/bricsys/bricscad/v12/bricscad
    I get
    [Thread 0xa361fb70 (LWP 17401) exited]
    [Thread 0xa24feb70 (LWP 17406) exited]
    The program 'bricscad' received an X Window System error.
    This probably reflects a bug in the program.
    The error was 'GLXBadDrawable'.
      (Details: serial 227706 error_code 149 request_code 136 minor_code 5)
      (Note to programmers: normally, X errors are reported asynchronously;
       that is, you will receive the error a while after causing it.
       To debug your program, run it with the --sync command line
       option to change this behavior. You can then get a meaningful
       backtrace from your debugger if you break on the gdk_x_error() function.)
    Program received signal SIGSEGV, Segmentation fault.
    0x1f090605 in ?? ()
    (gdb) bt
    #0  0x1f090605 in ?? ()
    #1  0xb4458277 in OdDbDatabase::release() () from /opt/bricsys/bricscad/v12/libTD_Db.so
    #2  0xb7c1fb88 in OdSmartPtr::~OdSmartPtr() () from /opt/bricsys/bricscad/v12/libodapp.so
    #3  0xaec4ae14 in __cxa_finalize () from /lib/i386-linux-gnu/libc.so.6
    #4  0xb60a1f64 in __do_global_dtors_aux () from /opt/bricsys/bricscad/v12/libwxgui.so
    #5  0xb67d1f50 in _fini () from /opt/bricsys/bricscad/v12/libwxgui.so
    #6  0xb7ff0c3d in ?? () from /lib/ld-linux.so.2
    #7  0xaec4aa6f in ?? () from /lib/i386-linux-gnu/libc.so.6
    #8  0xaec4aacf in exit () from /lib/i386-linux-gnu/libc.so.6
    #9  0xae774921 in ?? () from /usr/lib/libgdk-x11-2.0.so.0
    #10 0xae1ac0a5 in _XError () from /usr/lib/i386-linux-gnu/libX11.so.6
    #11 0xae1a90ea in ?? () from /usr/lib/i386-linux-gnu/libX11.so.6
    #12 0xae1a9ca5 in _XReply () from /usr/lib/i386-linux-gnu/libX11.so.6
    #13 0xaef09070 in ?? () from /usr/lib/nvidia-current/libGL.so.1
    #14 0xa9961dfc in ?? () from /opt/bricsys/bricscad/v12/libREDOpenGL.so
    (gdb)
  • yep, mine crashes too, probably a minor issue with the preview.
    I must say overall, the 3D is working well.  I'm still trying to figure how to get my two GTX560s in SLI mode, but just with one things are snappy.
  • same here, everything i need is working so i'm not complaining, just letting them know.
