sofoco tools v12 is not working with bricscad 12.1.20 version
From Sofoco tools I'm using "Mtext these text" and it works here.0
Hi Kotesh. What exactly is not working?0
i am not getting sofoco toolbars on the existing toolbars. even no floating toolbars. if i right click on toolbar, sofoco tools toolbar option is available with earlier bricscad versions.0
Here is working fine - bricscad 12.1.20 version0
If I understand well, try just (re)load PARTIAL cui file sofoco.cui file to Bricscad direct Customize (command CUI).
You find it at (in my case): c:\Program Files (x86)\Sofoco\SofocoToolsV12\SofocoTools.cui0 -
after restarting the system, sofoco tools start working. thanks for your help.0
